Question regarding offset printing
ks69
2012
Estonia
Hello,
Im a beginner in offset printing and looking for some help.
I have been printing business almost 5 years now. We started as a printing agency. Today we have digital printing equipment. But still most of the turnover comes from offset print jobs that we order from varios print mills and sell to clients.
My question is that how do i calculate print cost with offset printing machine? I ask it because i would like to do little calculation that could we earn some extra if we buy our own machinery?
All i know is the price of paper. But what about print plates (if you call them this way in english), paint, maintenance cost of machine etc.
best regards
Kaupo
Hi. Yes we call them print plates, but we call ink - ink, not paint, as it is "Chernila, ne kraska" in you understand Russian :)
to my best understanding, here how it works:
1) You have cost of the plates made and installed on the press and aligned with ink keys set and press ready to run - this called makeready.
2) Than cost of the press run, usually per 1000 impressions
3) Than cost of media / paper.
I worked with printer who had a 14x20 RYOBI 5 color with Aqueous coater, he charged me a $120 for makeready, $80 per 1000 sheets for 80# paper or $120 for 12pt cover.
The makeready cost consist of plates (about $2-4 per per plate), time, materials, platemaking equipment usage/depreciation cost, cost of the time spent preparing the press to run the job+profit.
Run cost included cost of paper+cost of using press+cost of the pressman's time+profit. It could wary if you running 1-2-4 or more color press, if some specialty stock needs to be run slow - it will more expensive, if in-line coater is used - AQ or UV - it may affect the price of running.
This is an example of running one job maximum sheet size. If you, for example put 9 different post cards on that sheet, divide Makeready+running cost by between 9 jobs, that will be the cost of each individual job.
Lets put this in the numbers... say we print 9 orders of 5000 different cards...
MR 120 + (run 120 x 5) = $720 so each order cost $80
All numbers may wary - if you want calculate your cost of production - you need to know things like:
Start with size of press you think yo can buy...
Cost of plates for that size of the press for the type of platemaking system type you want to get.
Cost of running platemaking system (chemicals, time/labor)
Cost of running the press (maintenance contract or average cost of owning / using similar press - you should consult with someone who already has similar press)
Labor costs etc.
I am sure I did not cover all of it, perhaps other guys could fill in....
  • We are also best offset printing company in India provide printing services with best printing technology
    hope to get latest updates from this forums.
    Thanks a lot. Yes i understan and speak a little russian.
    I think you covered most of my questions. If i will be stuck somewhere then i write here again. Thanks again!
    Best regards,
    Kaupo
    Hi
    Printing cost depend what kind job is going to be print.
    1-cost of designing.
    2- cost of plates which will used in job.
    3-cost of printing machine.
    4-cost of folding.
    5-cost of cutting.
    6-cost of binding.
    7-cost of packing.
    8-cost of labour.
    9-cost of delivery.
    MR UnlimitedBT expalin u good by giving example.
    Hi
    4-cost of folding.
    5-cost of cutting.
    6-cost of binding.
    7-cost of packing.
    8-cost of labour.
    9-cost of delivery.
    and what about profit and overhead????
    Awesome print yield calculator, thanks
  • I have the same question, is there any software/ program which can easy this process of making calculation...?
    Rates also vary by geography.
    I know printers in India who print a CMYK 4 col 28"x40" job by charging USD30 for make ready including plates. And print charge of USD10-12 per 1000 sheets with a minimum print charge for 2500 sheets.
    And you should factor in regulatory costs which might be imposed in your area.
