Here is another piece to the puzzle when troubleshooting air leaks on the short stroke cylinders.
You will notice they have two 6mm air lines running to them. This is a binary set up in effect, one is on the other is off. They never both have air going to them at the same time. This is important because it is where alot of people get confused when troubleshooting which cylinder is bad.
Typically what happens when you manually activate each cylinder you eventually come across the one air circuit that has the bad cylinder. When you do you will initially hear the air leak coming from the 5/2 way valve which releases the air to either side of the cylinder depending on whether you are going on impression or off impression. DO NOT REPLACE THIS 5/2 WAY VALVE! It is not the problem. People tend to think because they hear it leaking it is the problem. I'll get back to why you hear sound coming from it in a minute.
Once you isolate which circuit is bad, it is very easy to find out what cylinder is non-functional. Go to either one of the cylinders on either side of the press. It does not matter which one. Take the air line loose that has no air going to it from one side of the cylinder. It is easy to tell which one will have no air as it is the one that will have the end of the ram farthest from it. (Where the lever being activated attaches to.) When you remove this air line one of two things is going to happen.
1. You will hear air leaking out of the air cylinder in front of you. If this is the case that cylinder is your culprit.
2. You will hear air leaking through the air line you are holding in your hand. If this is what is happening it means the cylinder on the other side of the press is the bad one. This also explains why you hear air coming through the 5/2 way valve, the air is looping back through the circuit and not allowing the 5/2 way valve to move fully to one position or the other, as a result the air leaks around the chambers in the valve making it sound like it is leaking.
It is extremely important when replacing these air pistons that you measure exactly the stroke length from the old one and adjust the new one exactly the same before installing. These pistons are responsible for not only the printing pressure but the alignment of the drive gears to the impression cylinder gears and plate cylinder gears. Being off just 2mm in length can affect the pitch of the gears. Most people think this is an easy replacement and mechanically it is, but a year down the line when you are experiencing axial streaks in your printing that will require a blanket cylinder gear replacement to fix or worse if you damaged the impression cylinder gear which can't be replaced, then you will understand how difficult this job actually is when not performed correctly.
If you have any doubts in your mechanical abilities when doing this, spend the money to have someone who has done it properly before come out and do the work. A knowledgable person can perform this job in an hour or less and will save you lots of money in the long run if you were to do it incorrectly.
