QMDI classic error message -FUSEFLT=FALSE. -OVRCURRENT = FALSE
Discussion in 'DI Presses' started by erictheprint, Oct 5, 2013.
  1. erictheprint
    erictheprint Member
    Dec 2009
    26
    Eccleston Lancashire
    Can't image or spool plates Had initial problem of blue screen with flashing cursor in bottom. Corner. Replaced SVK board and got into press control screen but lost mouse So altered MS DOs settings until it worked
    Error message when trying to make plates or spool them is TFLT and Errormessage in special functions screen is-FUSEFLT=FALSE. -OVRCURRENT = FALSE on all 4 units Have checked 5 volt and 36 volt which are ok. Have tried new 5v and 36v boards in still same fault have also put new main power box in as well still same fault
    Restored hard disc to date prior to fault and still same
    Could it be the monoitoring of voltage and current is faulty and if so what does it
    on Heidelberg test diagnostic cannot detect any of the boards
    Any Ideas Please
  2. Frank Taylor
    Frank Taylor Member
    May 2013
    40
    United Kingdom
    First problem was the hard drive, which is now resolved.
    Second problem was the console turning off Blowers on, which has been resolved by fitting a new SVK pcb.
    Third problem pictures below:
    Pictures showing the fault.
    Power supply 5Vdc & 36Vdc & tested and working.
  3. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
    The problem is definitely related to the 5v/36v power supply when this error comes up. Somewhere the Laser Drive Modules are not getting the voltage. I have seen this when the fuse on the power supply is blown.
  4. ronrogers
    ronrogers Member
    Dec 2010
    42
    minnesota
    Paul, on a different note. We have an error message this morning SF 15-11 on our QMDI Plus the manual does not show this error. Says CMOS keyboard battery is low? Hit F1 for setup or F2 for default settings, neither does anything
  5. Frank Taylor
    Frank Taylor Member
    May 2013
    40
    United Kingdom
    Ron, not seen 15-11 but could be due to CMOS battery error. As to the keyboard. A number of things to consider : (a) Interface between the keyboard and PC you're best checking the keyboard works by entering DI Dos screen via the KeyBoard then testing the keyboards buttons F2 & F1.
    Is your DI down? Or still running ( working ) ???
  6. Leonard Enterprises
    Leonard Enterprises Member
    Aug 2009
    43
    Rhode Island 401.338.0420
    Afternoon Ron 15-11 is a communication problem between ewm and computer or eam 24volt issues could be cause but battery memory issues as we'll give us a call
  7. ronrogers
    ronrogers Member
    Dec 2010
    42
    minnesota
    It was the CMOS error Mother board Battery.
  8. 72hrprint
    72hrprint New Member
    Nov 2013
    New Port Richey, Fl
    i have the same issue. it is not my power supply. i wanted to reply to the post to see if you ever got your issue resolved and see if you could help me to fix my press. I am having the exact same issue.. TFLT error. All 4 units, but my supply is fine.
  9. Frank Taylor
    Frank Taylor Member
    May 2013
    40
    United Kingdom
    sorry for the delay.
    I managed to fix the problem in the end. I found 5 volt DC to pcb faulty. Correct the problem and press was back up and running..
    Have you still got the same problem too :)
  10. qmdipress1
    qmdipress1 WWW.QMDIPRESS.COM
    May 2009
    184
    ct usa
    QMDI Prress Services
    www.QMDIPRESS.COM 1-201-264-1553
    Sales/ Service/Parts/Plates
    Heidelberg/ Ryobi DI presses
