tmpord
- 2010
- 9
- Thessaloniki Greece
Hello. My qmdi 46-4 plus press has some problems. While it was running normaly, suddenly stoped working and the lights on the control panel turned off and the fans started working without stop. It was need to turned off the machine and restarted it again so it will work and also again after some time it makes the same. That was a problem for some weeks and one day the engine air compressor stopped working. I found that a cable in the main switch of the machine was defective and dammaged all the main switch so i changed the main switch and put an ABB switch. After that the engine started and the air compressor worked normally ... Now the problem is that it dont allow me to burn plates and it shows me as fault that 12V and 36 V dont work and i read in the service manual of the machine that maybe is the power supply.
Because there is no electronic person who can help me with these problems and because I am not electronic by myself please if someone can tell me step by step (even with images) what i must to do so the machine will running again normaly.
I am attaching some pictures.
Thank you in advanced.
