QM46 classic don't set ink profiles
derec
2015
9
MX
Hi everybody, I am working on a QMDI-46-4 classic that have a problem with ink fountains and rollers. After imaging the computer freeze, and don't set the ink profile. Also doesn't move the motors.
I have tried some options:
- Delete old ink profiles
- Run a scandisk
- Run a defrag
- Checked cable from EISA to MAR4
- Change all MAE rack (from another working classic)
- Change EISA card
- Checked all motors and potentiometers
- Checked cable continuity
I will apreciate any other ideas. Thanks.
did you check DIP switch positions ( on the card inserted into QM PC ) ? maybe someone accidentaly change position of switches. be carefull with that and check on another QM classic which working well (compare your and settings on other machine).
  • Thanks for the tip, I guess you are talking about EISA interface card.
    I set the DIP switches according to the Manual (S1: 1-2 Off, 3-4 On, 5-8 Off). I also tried 2 other ISA cards (not EISA), and them had a smaller DIP switch, may be this cards are not for Classic.
    I'll check continuity directly on the board.
    Thanks QMDavor, and I will tell you my results.
    "I set the DIP switches according to the Manual" - I've had similar problems with my press. I set my DIP switches according to the manual but they weren't actually correct. I realized this once I met another person with the same press whose DIP switches were set differently. The best thing to do would be to find another person with a working press and compare your switches' positions. I could upload a photo of my own DIP switches tomorrow.
    Thank you for the tip, I'll see if I can have access to another DI Classic to compare, and I appreciate the photo of your card.
  • Thanks QMDavor, certainly DIP switches are misconfigured, the manual gives me the reversed configuration (1 corresponds to 8 and vice versa).
    These days I do the test, and comment the results.
    Hello again, I just checked the machine, I was testing with switches settings you gave me, and it did not work, but the problem was solved already, was an IRQ conflict.
    Thanks anyway QMDavor, and I share the solution if can serve someone else.
    By the way, in my case the switch configuration matches the manual. I attach a photo.
    Sn9mG0iJ8DGavJ6OJjwnVsoKTxo9FuGi0HbvlgkOlDSnXK9JjNb3MJ6hNEyhb9Wi
