QM-46 air pressure
Discussion in 'Heidelberg Printing Presses' started by wiscowi, Sep 24, 2024.
  1. wiscowi
    wiscowi Member
    Jun 2019
    24
    wisconsin
    We have 3 QM-46s and one of them will hard stop because the motor for the air pressure does not turn on soon enough to keep the pressure up. It's ready to go again after maybe 3 seconds and out of all 3 it has the strongest pump. Is there a sensor/switch that can go bad and cause the delay or what would cause the pump not to kick on soon enough?
  2. CHOCK
    3,051
    Hi Sir;
    Clean very well the sheet monitor device with contact cleaner spray
    ; 1) Sensor 2) +light barrier , is there in the feeder. Look, too for loose wires, or corroded, or semi broken, false contacts, or Faulty Device.
    However, examine, the hoses, from the Compressor, if there are some small Leaking, causing the delay, and of course clean or change the filter of Pumps, very well.
  3. sean crawford
    sean crawford Member
    Jan 2020
    19
    Chicago
    Behind the guard of the feeder hand crank, down at the bottom of the air tank there are 2 pressure switches. One for periodic moisture release, the other for the compressor on/off. I've had this problem twice with different presses and found that replacing these switches is the best option. There are contacts and adjusters inside the switch, one side for low pressure, the other for high pressure. Each Switch is behind 2 small black plastic guards. I will try to find a part number for you
  4. sean crawford
    Jan 2020
    19
    Chicago
    You can verify with SF-56 error 11-02 while the press is running and then stops. The error will disappear when the press re gains pressure. IMG_2199.jpg IMG_2200.jpg
  5. Steve F
    Steve F Member
    Jun 2013
    52
    Scotland
  6. wiscowi
    wiscowi Member
    Jun 2019
    24
    wisconsin
    Alright thank you for the reply, are the switches the Y19 and Y25? I feel like the one that opens for condensation has been a problem in the past so that would make sense. Or would it be in the black compartment coming out of the tank?
  7. sean crawford
    Jan 2020
    19
    Chicago
    The actual switches are behind the black guard, if my memory is correct, one is for high pressure turn off, one is for low pressure turn on .
  8. wiscowi
    wiscowi Member
    Jun 2019
    24
    wisconsin
    So I swapped out the Y19 and Y25 pieces and I also took them apart and cleaned the inside of the rod where there is a spring and plunger, and still no luck. I noticed that the blow off valve (Y19) doesn’t actually do the discharge, it’s always Y25, is that normal? I took off the black cover and noticed the P with arrows, would that be an adjustment to help the pressure stay higher?
