Good morning David, If you are referring to registration between the 2 color units on the press, the only thing that would cause a problem would be a loose blanket, or an over- packed blanket that could pull a plate out of the clamps from too much pressure. Otherwise, colors should register perfectly. Problem could be in plate making, be sure to use metal only, not poly plates as they can stretch easily
