Printing Plastic Cards on Indigo
Discussion in 'HP Indigo Digital Presses' started by BRC, Mar 10, 2020.
  1. BRC
    BRC Member
    Oct 2013
    27
    MN
    We are looking to print thick plastic cards on our indigo. We were thinking 15mil pvc with 10mil laminate. Any suggestions on this or anyone that is currently doing this?
  2. krukov
    krukov Member
    Oct 2019
    48
    IDK
    You mean 15 milimeters thick?
  3. BRC
    BRC Member
    Oct 2013
    27
    MN
    No, 15mils is the equivalent of 0.015" or 15pt or 0.381 millimeters thick
  4. krukov
    krukov Member
    Oct 2019
    48
    IDK
    Its possible on S2 sheet-fed Press. I did it but only with new blanket for 10-20 sheets. Better to put primer on that pvc.
  5. FFR428
    FFR428 Senior Member
    Feb 2008
    438
    CT
    I used to run thousands of 12x18 14 mil vinyl on our old 5600. GPA is a decent vendor for plastics and vinyls.
  6. BRC
    BRC Member
    Oct 2013
    27
    MN
    When you were running the 14 mil vinyl, were you using a laminate on the front and back?
  7. amimnagh
    amimnagh New Member
    Dec 2020
    Ontario Canada
    What did you think of the Indigo? Looking at getting one for short run Plastic Cards? Can I ask why you got rid of it?
  8. FFR428
    Feb 2008
    438
    CT
    Our lease ran out. Boss wanted to move in a different direction. The indigo ran well. A bit hands on with maintenance and repairs. But ran the plastic pretty well. Learned some good tricks for difficult subs. We had white ink which was a great option.
  9. Harrington4Life
    Harrington4Life New Member
    Dec 2020
    Kansas
    We use Tekra 015. Our 7900 and 5600 machine will duplex this without problem. Afterwards it get a 5mil or 10mil laminate applied to both sides.
  10. rolermanto
    rolermanto Senior Member
    Dec 2011
    138
    italy
    Hello,
    so with Tekra 015 you can print duplex without problem?
    It's interesting to know this... Thank you for share
    Luk
  11. Harrington4Life
    Dec 2020
    Kansas
    Well the 5600 we had more issues with but the 7900 has been great. It is still a newer press but has held register just fine. Just has to be in one-shot mode.
  12. FFR428
    Feb 2008
    438
    CT
    When we ran the Tekra subs were too were able to duplex the sheets. Sometimes we had to tape the gripper fingers.
  13. rolermanto
    Dec 2011
    138
    italy
    Yes One shot is necessary... without its really difficult not have misregistration
  14. vimal m raj
    vimal m raj Member
    Jul 2019
    14
    ca
    Yes we are doing this 15 MIL to 20 MIL INDIGO 2000 CONT 5105122357
