POS-CTRL problems
Hello guys,
The error still remains.
We have been swapping out cards in every station with no luck still.
On monday we will try to connect Rodimo to the control station and hoping that shows us where the error is.
As you guys mention here above, the Node 8 - subnode 1 is in the feeder. We have swapped out cards in the feeder and the error stays the same. Also the control station is not working - prob. because of the Node 8 error.
Also we have tried swapping in all of the 4 printing units with no luck.
Anyone have any thougts on the matter going forward?
  • Remove from feeder rack control board of the feder timing, slot 6 and try.
    ..I am sure you have at least one bad POS controller .
    One of these? (see photo)
    Yes.
    But why all board's shining?
    Shoot the other PU.
    Break the process lup.
    Normally no light on the step motor board's.
    One of the error messages is about the feeder timing motor.
    Call. it's easier.
    Update:
    We could not connect the Rodimo program to the PCB in the control console. (but we could connect Rodimo to the other board)
    Could it be that one of the component in the board is not workin - thus these errors?
    Rodimo does not help for process. The board in the picture is working 100%
    hello
    you have problem with color console process controller board, and it is located near to main leitstand computer process rack slot 2.
    newer version and old version have different part numbers, but boards are same no problem. installed the new board in color consol pos rack and delete EEPROM then save data to EEPROM by using the key disk floppy. if you do not have a key disk floppy or don't know how to use it try swapping EEPROMs from old to new board.
    did you try as I told you?
  • Rodimo does not help for process. The board in the picture is working 100%
    then whay can we connect Rodimo to that board? The other board beside works with Rodimo.
    We have swapped and replaced boards all over the machine.
    The feeder motor is working etc.
    So this is getting a little wierd.
    hello
    PC is connected to the process bus master via plug X9 on the interface converter board in Slot 6 of the Leitstand computer (lower Sub-D-plug)
    Connect your PC, run Rodimo, and check the status of the node that is not working and the status of the process loop.
