POS-CTRL problems
printer55
2020
82
USA
Hello guys,
Anyone had these issues?
Node 8 - subnode 1
Any toughts?
Yes. Open the machine configuration and see where the problem is.
.....The last error message, "color console not responding", is much more interesting.
  • Yes
    Possibly the board with a reset button in the rci, that's where I'd start looking
    Possible. .... 10-40%. ..depending on the number of PUs
    Where is this reset button?
    We have 4 units.
    We have maybe narrowed this down to one of the boards in the console who talks to the color controller.
    There is no reset button in Roland 300, 500, 700, 900. There is a button that changes the direction of communication. The red (when the cap falls off it turns black) button is for changing the communication: control console - hand terminal. Depending on the software version, it is often necessary to restart the machine with the main switch to return communication to the central console.
    The message about the lack of communication with the RCI can be received from any similar board in the machine. Defect of the self-diagnostics.
    Board in RCI is different from the others.
    I got a new PCB board from Man Roland.
    The numbers are not the same as on the old board - but it looks the same.
    Do the numbers have to be the same on the board or are they diffrent because the new one is a newer version?
    New PCB board did not work - any ideas?
    Also tried swapping other boards from the print towers.
    The machine has still: color console does not answer
    So it can be a board inside the machine? Not in the leitstand?
    .......The message about the lack of communication with the RCI can be received from any similar board in the machine. Defect of the self-diagnostics.
    Yes
    Replace the board from the delivery with a board from a PU.
    Attention!!! POS should be repaired ONLY when the machine is switched off.
  • Yes
    Of corse, always turned off when doing anything.
    So this is maybe not in the leitstand/comsole?
    Are the node errors connected to this? Came on the same time.
    Hello guys,
    Node 8 - subnode 1
    Any toughts?
    hello
    you have problem with color console process controller board, and it is located near to main leitstand computer process rack slot 2.
    newer version and old version have different part numbers, but boards are same no problem. installed the new board in color consol pos rack and delete EEPROM then save data to EEPROM by using the key disk floppy. if you do not have a key disk floppy or don't know how to use it try swapping EEPROMs from old to new board.
