Polar92 backgauge load error
Discussion in 'Cutters and Trimmers' started by Altangerel, Sep 24, 2024.
  1. Altangerel
    Altangerel New Member
    Sep 2024
    Mongolia
    Dear Colleagues
    I just bought Polar92 cutting machine but backgauge location unknown and it would not work. Please help and advise.
  2. Adil
    Adil Senior Member
    Nov 2021
    1,086
    Casablanca
    Hi sir
    You should do the procedure manually .
    Please remove all paper on the table and push number one then you must continue the procedure .
    It s not hard you have to enter the distance manually
  3. Adil
    Adil Senior Member
    Nov 2021
    1,086
    Casablanca
    Hi sir
  4. ESPofKC.com
    ESPofKC.com Member
    May 2014
    15
    USA
    No pulses means it is not getting pulses from the encoder. 1) Check the plug for the encoder, 2) Check the mechanical linkage, 3) Check backgauge motor and belt.
