Polar Mohr 92 CE – Gearbox & Hydraulic Oil Service Help Needed
Polartom
2025
9
France
Hi,
I own a Polar Mohr 92 CE paper cutter and I would like to perform a complete oil service.
I am looking for:
A- the exact location of the gearbox drain plug
B- the filling/level point to refill it with EP220 oil
Also regarding the hydraulic system:
1- where to properly drain/purge the system (using an extraction pump?)
2- where the filling point is located
3- the correct hydraulic oil type (HV46, HM32?)
I can also provide photos of the machine if that helps guide me through the process.
If anyone has photos or the workshop/service procedure, I would really appreciate it.
Thank you for your help!
Tom
Hi,
Just to clarify, for now I am focusing only on servicing the gearbox oil.
Could someone confirm if my understanding is correct:
• plug marked “2” = drain plug?
• plug marked “1” = filling/level plug for EP100 or EP220 oil, approximately 0.5 L?
I would also like to replace the seals while I’m at it:
• 205622
• 200936
Does anyone know an equivalent part number or a compatible seal still available online? These old references do not seem to return anything anymore.
Thank you for your help.
Tom
