Gizmo
- 2026
- 4
- Russian
Good afternoon.
Polar Mohr 137E (E/C, CP5, V4.0.0-0)
Please could you help me identify the cause of the fault?
The cutter (working unit) was moved to a new location. We reassembled it after three months of storage.
Problems:
1. Error 133 (D1-off, D2-off, D3-off, D4-off, D5-on and D6-on - Protect. areas were never ‘unobstructed’ since ‘Voltage ON’)(measurements on SK95 – 24V/12V/5V within limits)(measurements on emitter and receiver within limits)(repositioned the working barrier from 78ES – to no avail).
2. No pressure is being built up in the hydraulic system (the pedal is not being held by the valve) (Figure 1).
Consequently, as there is no pressure, the pressure beam does not lower.
Thank you for your help.
I’ll try to reset the Service menu tomorrow (take photos of the parameters) and take additional measurements in the circuits.
Please advise how the safety bolt should work on this model (and how to check it).
There is a suspicion that during final assembly and transport using a forklift, the mechanic rested the pressure plate against the forks and moved the machine in this way. Could the heavy weight (of the machine) applied to the pressure plate have damaged the mechanical components or the hydraulic system?
Problems:
