Polar emc 115
Discussion in 'Cutters and Trimmers' started by MRTYMM, Sep 5, 2022.
  1. MRTYMM
    MRTYMM Senior Member
    Apr 2015
    137
    egypt
    I have cutting problem with my cutter. The fault is that lack in 2 mm
    Also when I make set value 30cm cut and the actual value is 29.998 and if set 50 the actual is 49.992
    I swap tam card from another machine
    And the problem is still foundthere is difference between actual and set value
    The problem from brake or lms
    How-to adjust brake Screenshot_2022-09-05-18-15-54-12_99c04817c0de5652397fc8b56c3b3817.jpg
