Polar EM 115 - Monitor Resolution
Discussion in 'Cutters and Trimmers' started by Vaggianak, Jan 7, 2025.
  1. Vaggianak
    Vaggianak New Member
    Jan 2025
    Greece
    I wish you all a Happy New Year.
    I'd like your kind help on the following: I turned on the monitor of my Polar EM 115, and realized that brightness was totally dark for some reason, as well as the resolution (text,numbers and characters size) was too large (words exceeding the limits of the screen). I was able to correct brightness with the buttons at the back of the screen, but what about the resolution? I can't find any buttons or information in the manual to correct this.
    Generally all features of the machine work properly.
    Do you have any idea?
    Thank you!
  2. Vaggianak
    Jan 2025
    Greece
    Photo attached, to help you understand
  3. ESPofKC.com
    ESPofKC.com Member
    May 2014
    53
    USA
    The adjustments are inside on the board. Please be very careful from high voltage inside.
  4. Vaggianak
    Jan 2025
    Greece
    Hello. Thank you for your answer. So I should look for a switch, or something similar that can be adjusted manually on the surface of the board? I haven't taken it out yet, I want to be sure.
  5. ESPofKC.com
    ESPofKC.com Member
    May 2014
    53
    USA
    They are potentiometers affixed to the PCB board. This may not be the problem but its the first place I would look. Again be very carful if you are new to this.
