Polar 92CE
Discussion in 'Cutters and Trimmers' started by Digipix, Jun 19, 2022.
  1. Digipix
    Digipix New Member
    Jun 2022
    South Africa
    Oil coming out between the drive shaft for the clutch,
    and going between the clutch plates.
    Any one perhaps have a parts manual , so that we get order the correct parts.
    Thanks in advance.
  2. Mehanka Abortmaher
    Mehanka Abortmaher Senior Member
    Apr 2022
    120
    Russia
    Take a picture of the gearbox, take one or two general shots and one of the clutch/brake. To understand the problem.
    I want to compare with 92XT+
  3. synthology
    synthology Member
    Apr 2017
    19
    us
    replace groove ring N 45-4 #205016 and o ring R 80-3 #205072
  4. Mehanka Abortmaher
    Apr 2022
    120
    Russia
    I looked at the Polar 92 X catalog, in my case the oil leak into the brake comes from two sources:
    1) Worm shaft seal
    2) The brake/clutch rod O ring is located inside the worm shaft.
    The replacement operation of items 1) requires disassembly of the brake/clutch assembly without removing the gearbox.
    The operation of replacing item 2) requires the removal of the gearbox from the equipment and disassembly of the opposite side of the brake/clutch, in my case, the hydraulic cylinder for engaging the brake/clutch, which is the end cover of the gearbox.
  5. CHOCK
    2,563
    Colleagues Synthology +Mehanka, are o.k/
    Procedure with this
