Polar 92 EMC - Error Code 83
Discussion in 'Cutters and Trimmers' started by barrprint, Apr 24, 2017.
  1. barrprint
    barrprint New Member
    United States
    We are getting this code frequently. I know it has something to do with the light barrier, but we cannot figure out how to fix the problem. Any help would be appreciated.
  2. CHOCK
    3,058
    Good morning sir
    Hope you are well, with his family
    Please do the following test for Polar 92 EMC error 83:
    1)Light barrer Reajust the same, bad adjustment
    2)test connecto CU4,LS600 SEE you schematic and wiring diagrams
    3)test the Flat wires between board AR vs IAR
    4) Protect the receiver side Light barrier,againt excessive stray light
    5)If all test point indicate before, NOT fix it.
    6) Exchange board LS, or IAR, or AR(main computer
    Let me know, any question or doubt.
  3. CHOCK
    3,058
    Did you fix it?
  4. barrprint
    United States
    Thank you for your input. We have not fixed it. I did call the heidleberg help desk yesterday and they asked me to check the board that is ibn the left sensor arm. We re-plugged all connectors and it still shows the code.
  5. CHOCK
    3,058
    Dear Sir.
    Please do the steps, that previously indicate very carefully,
    You will have result, exactly from Factory Polar, If you waste his time
    doing anothers, you must waste money, and time .
    I can assure you , the steps are very exactly.
    However you must see by" Common sense", if there are some connector loose, pins broken
    loose wire, or some dry joint, or cold joint, in this case Resolder the board mentioned before.
    To due the age machine, and vibration for the same paper cutter.
