Polar 78EX
Discussion in 'Cutters and Trimmers' started by Tariq, Oct 13, 2024.
  1. Tariq
    Tariq Member
    Jun 2024
    10
    Jordan
    Dear All,
    My polar 78EX shows fault message (locking valve 25v faulty),could you please advise the cause of problem.
    Best regards,
    Tariq
  2. Tariq
    Tariq Member
    Jun 2024
    10
    Jordan
    Sorry it's 78ES
  3. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    Hi tariq
    This error message indicates that input signal "locking valve 25V" to board CP
    has not been set. the 25-V voltage supply of locking valve Y315 must be
    verified
    this error also may be caused when the computer voltage is dropping too fast.
    - Measure supply voltage of 25 Vd.c. for locking valve Y 315
    - Check mechanically if locking valve is functioning
    - Measure solenoid (9-22 ohms)
    - Check fuse on DC board.
    - Rectifier AC board
    - Check transformer and replace it, if necessary (plug 94).
    - Check correct setting of DIP-switches on CP board must be on ES
    - Short circuit in cutting circuit transformer area. (Check cabling.)
    Good luck and let me know
    Tariq likes this.
  4. er.bajaj001@gmail.com
    er.bajaj001@gmail.com Senior Member
    Aug 2015
    110
    India
    Hydraulic can be a Problem as well. Check the oil level.
  5. Tariq
    Tariq Member
    Jun 2024
    10
    Jordan
    I found the problem... damaged rectifier which is responsible for supply the valves,thank you.
  6. Adil
    Adil Senior Member
    Nov 2021
    1,398
    Casablanca
    Good job .
    Be welcome
    Tariq likes this.
