I'm facing a problem with Polar 78ES. After turn on and make 2-3 cycles, on the screen I have error 131 and changes to error 132 and again 131 and 132.On SK95 I have red led V88 on. Does anyone had faced similar problem?
Hello Nick, let me know if the machine can work even though the error appears on the screen and let me know if the lighting system is working without problems, both the cutting line and the work area lighting.
message 132 (interrupted cutting circuit) is just a consequence of 131 (static fault cutting circuit), it is therefore necessary to check the carte sk95 at an electronics technician + detectors and wiring of the cutting circuit. check the blade up control + light barrier + the relays in the cable for the elevator control button panel (short circuit)
