Polar 78 x Display
Discussion in 'Cutters and Trimmers' started by Laurie Dempsey, May 29, 2023.
  1. Laurie Dempsey
    Laurie Dempsey New Member
    May 2023
    New Zealand
    The display on our 2007 model guillotine has failed. we get a brief dull flash in the screen when the unit is powered up but display is unreadable. we are waiting on a suitable electrician to check the power supply but he is a few days away. Has anyone experienced this type of failure & is it likely to be a power supply or has the TFT screen died ? We have been using it up until today when we have unfortunately caused a backgauge position failure & without a screen can't navigate our way to resetting this. The tft is nearly $10k & 10 working days from Polar.
  2. CHOCK
    2,746
    Hi sir
    You must test in the 3 PCB ;
    A)
    1) kc +24Vdc
    2) DAK output 350V for backlight
    3) LCD / PLASMA /TFT Display 350 Vdc of input for backlight.
    B )look for V6 LED in KC must be ON =+5Vdc.
    C) Look for connectors loose, or corroded, or faulty, or bend pins.
    D) Flat cables or ribbon cables, loose, or faulty , or corroded, or bend PINS.
