Martian
- 2017
- 14
- South Africa
Hi all, I am having a strange problem on a Polar 76EM with LMS.
The backgauge size was out by 1,9mm. I corrected size using TAM pots as done many times before, and recalibrate after adjusting.
Size will then be correct and accurate.
But every time the gauge moves over the reference point on the scale the size will "jump" by 2mm. It is on a very specific point everytime that this happens.
After recalibrate, I can bring backgauge to 280mm, then move the gauge forward with handwheel, and as soon as it gets to 276,2mm it will suddenly change to 274,2mm.
I have not experienced this issue before so if anyone has seen this before if you can please pass on some advice.
I am thinking it must be fault on LMS but good chance it can be fault on TAM card.
Any advice would be appreciated
