Polar 76Em knife freeze on return
siraj
Hi CPF,
We have polar 76Em, and the knife gets freezed always when its returning to TDC from BDC, to be clearer after cutting the stock the knife stops at mid position, sometimes at middle, sometimes at nearer to Tdc or even above 5cm from cutting stick, we dont get any error messages, sometimes we get 87,89,So we also checked safety bolts, cutting buttons contacts NO and NC, everything is fine, finally we tried exchanging IAR and AR boards along with flat ribbon cable still the problem havent solved, any quick advices to solve this issue,? We have been trying to solve for more than three months, but we failed this much long (we have also exchanged the card from this machine to other machine and everything is working normal in other machine). Thanks in advance.
Hello,
Try to check the microswitchs related with the cams, the correct adjusting of them and the complete wire between cams microswitchs and the CU connectors board. let us know the results. Best regards.
  • Hi Siraj, Did you ever find a solution to this problem? I am still having the same problem with no solution, any help would be much appreciated..
    Let me know, what is the problem in order to help you
    Thank you in advance, sincerely
    Yes i did solved the issue, adviced by @oabrahim in one of the reply in this thread, i have adjusted the cam switch which is available at the back of the machine, one of the switch was faulty, and i replaced both and its working fine now. You can find this switch, on the back side of the machine in right direction next to the flywheel or above the gear oil replacing manifold. If any pls progress let me know.
    Good job
    How can we adjust this switches on the cam s22a ,s22b
    Hi Guys,thanks for the courteous replies, I have had this problem for a long time and sometimes it is worse than others, currently it stops almost after every cut. I have had a couple of engineers look at the machine with limited success,I believe one of the switches was replaced the last time and it seemed to help for a while, any further ideas or advice would be much appreciated?Thanks
  • Have
    Hi Guys,thanks for the courteous replies, I have had this problem for a long time and sometimes it is worse than others, currently it stops almost after every cut. I have had a couple of engineers look at the machine with limited success,I believe one of the switches was replaced the last time and it seemed to help for a while, any further ideas or ideas would be much appreciated?Thanks
    Have you tried changing the relay at back panel? You can find this relay in the back side of the mother board panel, the relay will be inside a small aluminium box, it has two relay inside it, check those whether it is in good condition.
    Hi
    Hi, I tried adjusting by the mark which is already marked in my machine, actually I found in my machine that switches are moved in up direction because of the loose alen screws, and also I have observed there is pointed tip in the teflon cam and black color marking in the cam.
