Polar 76EM Keyboard
Discussion in 'Cutters and Trimmers' started by Bradley Crawford, May 16, 2019.
  1. Bradley Crawford
    Bradley Crawford Member
    Apr 2019
    7
    Pictou, Nova Scotia, Canada
    None of the keys are working on the keyboard after what may have been static discharge from cutting synthetic stock. The display shows proper position but there is no way to program. There is 5V and 9V being supplied to the board.
  2. CHOCK
    2,877
    Hi
    is there the +5 and+9 in tolerance in 5% ??? example if you get +5.6Vdc out of tolerance, repair or replace, and similar.
    Lets check this, please, if there are try to clean the connectors very well, from oxide, and dust.
    2) Look for dry and cold joint solder, and reheating the boards.
    3) if everythings is o.k , time to replace the Keyboard board
  3. CHOCK
    2,877
    attached example for solders.
  4. Bradley Crawford
    Apr 2019
    7
    Thanks you so much for the quick response. There is 4.95v and 9.1v at the test points. The display is functioning and I have reworked the solder joints for the ribbon cable and power supply connectors. I was suspecting either the KDI board or the keyboard board but was having a difficult time finding a replacement. Thanks again.
  5. CHOCK
    2,877
    Hi.
    Great you must replace the Keyboard board.
    I can supply , let me know the 1) serial number machine 2) Model 3) Part number
  6. Bradley Crawford
    Apr 2019
    7
    Model: Polar 76 EM , Machine # 6061321, Board # 019970.
  7. CHOCK
    2,877
    ok i will send you by Monday the quotation.
  8. Print Service
    Print Service Member
    Jan 2019
    17
    Canada
    Does the backgauge move to position when you enter a number?
  9. Godwill
    Godwill Member
    May 2020
    6
    Kenya,nairobi
    Hello am having the same problem how much is keyboard and card KDI
  10. CHOCK
    2,877
    ok, will quotate
    Give me the delivery country address for calculate the freight to your country
    Let me know quickly.
    Blessing.
  11. Godwill
    Godwill Member
    May 2020
    6
    Kenya,nairobi
  12. CHOCK
    2,877
    Let me know the 1) serial number machine 2) Model 3) Part number+4) delivery country address for calculate freight +5) email for to send you the complete quotation
  13. Godwill
    Godwill Member
    May 2020
    6
    Kenya,nairobi
    And one of the IC in the card has a swollen part can it be the cause.....i can't even calibrated
  14. CHOCK
    2,877
    can be a good Possibility.
    Try it to replace, after first test the power supply, if is in good Tolerance. o.k??
    Measure the power supply to the input primary in the main transformer, maybe you need to install Regulator Voltage Transforme from Polar.!!
  15. Godwill
    Godwill Member
    May 2020
    6
    Kenya,nairobi
    Also cardLS have an issue error led 25 is On
  16. Godwill
    Godwill Member
    May 2020
    6
    Kenya,nairobi
    How can i go about that
  17. CHOCK
    2,877
    measure power supply in all CU unit, as i did indicate you , can be a problem with the Input voltage in the machine
    maybe you need to install Regulator Voltage Transformer from Polar, since that are affecting electronic boards.
    1)measure the voltage in LS +24vDC ??
    2) Test the connector CU4, can be some interruption or bad contacts, or dirty, or bent pins or corroded , clean it.very well, loo for dry +colder joint solder.
    3) is everything is o.k , the only way is replace the card LS.
