Polar 55 EM - Knife Return Spring
Axel Serbanescu
2024
Satu Mare, Romania
Hello,
We are looking for the following spare parts for the Polar 55 EM Guillotine, serial model 5805016:
  • Knife Return Springs
    • Specifications:
      • Number of coils: 43
      • Total spring length with hook: 320 mm
      • Spring length: 285 mm
      • Coil diameter: 46 mm
      • Spring wire diameter: 6.6 mm
Unfortunatelly is very hard to find on the web this spare part.
Do you know where i can find these?
Hello,
    • Specifications:
I have had springs made by local spring companies. You might be able to do the same with the detailed information you have.
  • Like espofks yold you you can do that with the localocal companies . I do that a lot of time
    It s not hard you have to know only the manufacturing material to have the same hardness.
    Thank you, who can tell me the material is made with or how can i find?
    Salut
    Problema e des intalnita pe modelele vechile 55EM si pe mai noile 66E/ES ! din nefericire arcurile furnizate de Polar au viata scurta. Suna-ma daca ai nevoie si chiar daca nu le am pe stoc le pot procura.
    giani
    The most suitable steel is usually a hardened spring steel, which offers a good combination of strength and flexibility. Specifically, 51CrV4 steel (chrome-vanadium alloy) is often used in paper cutters because it resists wear and fatigue well under repeated loads
  • Hi sir:
    I can quotate original, need the parts number, quantity, model machine, and serial, quantity, delivery country for calculate freight.
    Send me his email.
    Thank you in advance, sincerely
