Polar 115x Clamping time interrupted 118
Bermen
2022
12
Philippines
Someone help me about this polar error "Clamping time interrupted (118)" if I long press the cut button, I get a error of * Clamp not lowered (134) thank you for help.
Hello Mr Bermen, check the V-belt of the hydraulic pump.
If it is defective, it delays the pressure time suddenly the machine stops the pressure process
  • Someone help me about this polar error "Clamping time interrupted (118)" if I long press the cut button, I get a error of * Clamp not lowered (134) thank you for help.
    I Have the same problem I dont know how to fix it.
    I already check sir, and still okay, but the error still there.
    When 1st powered on does the clamp move down and return when only using the foot pedal?
    Also Check for excess preclamping time adjusted in the menu if set to high, it could be as simple as your not waiting long enough.
    Few other things but check these out
    There's a pictographs display when the error came up, i look in the manual its tell of "Undercut"
    Parameter one and two are to do with clamp and knife delay timing , set both around about two / three.
    what are they set at the moment?
    1 sec. For pressing time before cut, pressing time no cut 1,2,3,4 Optimization of clamp 1
    Error No.: 118
    Error Text: CLAMPING TIME INTERRUPTED
    Cause: Indicates that a clamping process already started has been interrupted. This is no
    error indication but a status message.
    Remedy: - Terminate clamping process
    - Observe possibly adjusted preclamping time
    - V-belt of hydraulic pump is defective
    What do you mean of terminate clamping process? Its my first time to encounter this kind of trouble. Gobless
    Setting 1 is fine it’s the shortest delay time
    Does the clamp move with the foot pedal?
    early post did you removed the flywheel cover and checked the smaller belt tightness and condition ?
