polar 115em monitor
Discussion in 'Cutters and Trimmers' started by printingco, Sep 17, 2009.
  1. printingco
    printingco Member
    Dec 2008
    11
    Sydney Australia
    just had a pre-owned polar installed by heidelberg & after being promised a copy of a manual i have yet to receive it (not too happy)
    anyone have a copy of the manual for polar 115em monitor?
    also any information on preventative maintenance, tips etc would be much appreciated.
  2. jose2209
    jose2209 New Member
    Nov 2017
    lima
  3. CHOCK
    824
    Managua
    Hi sir
    Let me know , what problem do you have for Polar?
    Blessing
    superchock@yandex.com
    cell+whatsApp:+50588611441
  4. fauzy indonesia
    fauzy indonesia New Member
    Dec 2017
    indonesia
    Minta tolong sarannya.saya lagi ada masalah dengan mesin potong pollar115em. Error 82
    Saat tekan pedal press muncul error 82.trimaksih
  5. CHOCK
    824
    Managua
    Dear Sir;
    the control transistor in IAR IS faulty for control locking valve y305
    try however to check connection with Ribbon cable between IAR -AR.
    Test : a) IAR + B) AR and replace if Necessary. See the schematic diagram
    Blessing
  6. Long
    Long Member
    Apr 2012
    10
    Malaysia
    salah satu valve bagi minyak hydraulic tak aktiv,
    uji wayer penyambung IAR and AR. makalah ada putus digigit tikus? kalau tak ada munkin kat IAR atau AR rosak
    semoga bejaya
    long
  7. CHOCK
    824
    Managua
    Hi sir
    Happy new year
    You must1) test the valve for +42Vdc AND See it if there are the +42 , if there are look for Y 315 if is defective in Hydraulic replace or repair, tight very well the connector look for corroded pins or desoldered , 2)TEST The flat wire and test for continuity
    and replace, 3)THE Control transistor is defective , you must replace.
    Otherwise you must replace the board IAR or AR
    However let me know in English to my email, for to some explanation.
    Blessing
Share This Page
