Polar 115 EMC sizes off
Discussion in 'Cutters and Trimmers' started by Robco, Mar 6, 2019.
Tags:
  1. Robco
    Robco Member
    Oct 2015
    8
    Tennessee
    Hello I have a polar 115EMC that is giving me a small problem. If you cut 20” then 10” and stack on each other they are different sizes. Is there an adjustment for this. I have scanned the backguage by moving it and shutting machine off. No help. I have changed knife compensation and strangely that does seem to help it some but not fixing g problem. Sure would appreciate any advice.
  2. CHOCK
    1,378
    Hi Sir:
    You can have this problems:
    1) Table is Not squeare to the knife carrier
    2) Backgauge is Not paralell to the knife
    3) Sledge guiding has play.
    4) Electrical adjustment must be carried, however angle 90 must exist between backagauge and table, use precise square.
    Test that steps.
    Let me know.
    Blessing
    superchock@yandex.com
    Mobile+WhatsApp:+505 8861 1441
  3. andy martin
    andy martin Member
    Aug 2016
    24
    bradford po
    If machine has a tam card you need to adjust red pots to correct the measurement
  4. Robco
    Robco Member
    Oct 2015
    8
    Tennessee
    Thanks Andy. It does have a card. I have managed to get it doing good now that I adjusted the .010 pot and then readjusting the knife compensation.
  5. andy martin
    andy martin Member
    Aug 2016
    24
    bradford po
    That's good to hear
  6. Robco
    Robco Member
    Oct 2015
    8
    Tennessee
    Yeah no fun backtrimming every cut to make sure they all come out the same.
  7. CHOCK
    1,378
    Hi Sir:
    Did you do this test ?? Please do it.
    1) Table is Not square to the knife carrier
    2) Backgauge is Not parallel to the knife
    Test that steps.
    Let me know, for to guide if the problem persist in another Test.
    Blessing
  8. Robco
    Robco Member
    Oct 2015
    8
    Tennessee
    Yes I performed all these tests. Problem persisted and I changed the .010 pot on the card. Cutting good now. Thanks.
  9. CHOCK
    1,378
