Polar 115 clamp system
USACUSTOMPAD
2026
12
new york
the clamp on one of my polar 115 is sluggish. Only on the way down and only when using the foot pedal. It zips down the first half an hour of the day then starts to slow to the point where it will barely move. We had this problem before and had the whole pump system relaced probably only 18 months ago. the foot pedal system is mechanically correct as far as the plastic cams and everything there goes and im just wondering if anyone has any insight into this problem. Why is it happening and can I fix it without replacing the whole pump again? why is it happening after only 18 months.
What kind of Polar is it EM ED, or what year is the machine?
Because it probably has to do with the oil filter in the hydraulic tank.
If a machine is from after 1995, the filter is likely clogged.
This filter often looks clean on the outside, but if you disassemble it and try to blow or suck through it, you will notice that it is difficult.
The easiest thing is to test the machine without the oil filter.
  • Dear, have a look on the attached picture, tried to make it simple and easier for any Tech/non-tech individual. Sluggish clamp movment means, either less pressure or leakage on cylinder or faulty valves.
    Try this:
    Turn On main motor --> Open hydraulic unit's cover and have a look at the hydraulic unit --> ask operator to press foot padel and have a look if there is any leakge at the valves/main cylinder (Cylnder is behind this Hydraulic unit), --> Now enable cut (because when the cut is enabled all solenoid valves operates and you can observe the leakage. If no leakage is observed, thats great but if there is any leakage, fix that.
    but if there is no leakage and still the clamp movement is slow --> Then observe the function of Solenoid valves # 2 & 3 as shown on the attachment.
    Note: Going slow up : There is Spring which moves the clamps up and downward movement is clontrolled by hydraulic valves
    SLow down movement when only the foot padel is pressed: Check valve # 1 and 2 and adjust using point A Locked screw
    Slow down movement when foot padel is not pressed but cut enabling switchs are pressed: Check valve # 2
    Less clamping pressure or paper slips when the cutting active: Check Valve # 3
    see the leakage at the cyonder :
    It would be great if you make a video while performing above sequence, we can directly guide you to the malfunctionig section. Hoping this will help everyone in the forum.
    Reagrds
    KOENIG
    Try this:
    Reagrds
    KOENIG
    View attachment 17001 View attachment 17002
    WOW,
    Thank you so much for the detailed response. It was super helpful. We have found a leak and I am attaching the video. It seems to come from the block and not from a solenoid itself.
    we had the entire system replaced 18 months ago so hopefully its something we can take care of easier.
    Try this:
    Reagrds
    KOENIG
    Hello Koening,
    I have been reading your detailed reply to USA CUSTOM PAD regarding the problems they are / were having with their Hydraulic system on their Polar machine. I am hoping you are able to assist us with our Polar 137 ED AUTOTRIM.
    We have recently purchased this machine and upon installation we found that the CLAMP is not coming down when the foot pedal is pressed.
    I can hear the hydraulic pump running but there is "NO MOVEMENT OF THE CLAMP AT ALL"
    When we try to cut however, the clamp does come down smoothly with the knife!
    I am assuming that our phases in our electrical connection are correct seeing that the cut function is working properly. Would I be correct in assuming this or could the hydraulic pump still be turning in the wrong direction? What direction should the hydraulic pump be turning in?
    We have NOT checked for leaks as yet (I only just came across your post now) but I will definitely check tomorrow. I will make a short video of the hydraulic system whilst the foot pedal is being depressed.
    If the clamp is working when cutting but not working with the foot pedal, what should we check first?
    Please could you assist with this issue? Any advice would be greatly appreciated.
    Kind Regards
    Shawn
