Pm52-2
FJPRINT
2014
Fiji
Main compressor won't start when machine is switched on, G30 error comes on. Circuit Breaker not tripped in the electrical board, Machine cannot run unless if theres air being supplied to the pneumatic parts inside the machine. Need advice on how to get the compressor running again.
So when you say main compressor, which compressor are you talking about. Compressor for pneumatics or compressor for feeder vacuum/blast air?
  • It's the compressor for pneumatics. It's normal for the machine to be switched on and then the compressor kicks in till it reaches the 10 bar mark and cuts off. As for this one, the compressor itself is not turning on.
    it all started after the machine had undergone automatic washup after running a job (single side print job). After the washup, the printing mode was changed from single side printing to perfecting, in the middle of the changeover the errors PO2 and P21 popped up on the display console and the changeover just stopped right there. The machine was not able to inch or roll even after the machine was restarted there was no change and then error G30 popped up which meant that there was insufficient or no air from the pneumatic compressor (compressor was not pumping )
    hey,
    not sure if this would work for you, but we had the same probllem here and we just opened the compresor and cleaned him up (all filters and so) - we found allot of dust in there :P After that it worked ok.
    Good luck
    The position of the perfecting mechanism is undefined. Therefore, the mahine must be steered back to a straight-ahead position. Normally, it is possible to restart perfecting process and the system will get back to straight.
    Actually we got this problem since two
    Years and my machine won't move
    Here in Ghana west Africa very difficult to get good engineers, we got 2 good
    Local engineers working on this but they can't find solution to this
    The press is moving with the crank from perfecting to straight manually
    But the error won't leave the machine
    well, what you need is a very experienced technician, who is able to move back the perfecting system mechanically by hand. But then, there could be a lot more problems with sensor, and so on. So, ask for a german specialist?
    Hello. You need to check the hydraulics of the perfector device.
