PM 74-2 year 2004 machine stops ..
Senarath Wijekoon
2024
Sri Lanka
We have a Heidelberg PM 74 -2 and machine stops suddenly and displays attached symbols. Please advise how to address this issue.
  • Hi sir .
    The cable of connection to the rotor position encoder is interrupted .
    Good luck
    Can you please advise us how to check the encoder interruption or whether the signal comes to the control card.. Thanks for your support
    according to the error code it means that the connection cable between the encoder and the motor is interrupted, if you have another encoder try it and check the cable with a qualified electronician, it is also possible that the encoder loses the information if you have already disassemble the encoder
    Good luck
    Whatsapp +212700552467
  • according to the error code it means that the connection cable between the encoder and the motor is interrupted, if you have another encoder try it and check the cable with a qualified electronician, it is also possible that the encoder loses the information if you have already disassemble the encoder
    Good luck
    Can you please advise what voltage or other signal should come from the encoder cable while running the machine
    the signals transmitted by the encoder are hall effect signals, and there is also a data transfer line to communicate with the main motor
