PM 102 Error
PM 102
give this error
  • Your delivery chain/side jogger greaser has either failed or run out of grease, or the sensor in the greasing manifold assembly is not sending signal.
    You need to manually activate the limit switch on the lubrication circuit, then you need to check if the grease bucket is full
    Activate the init switch on the delivery
    Which type of greace do you use ?
