Pip skewing
Discussion in 'HP Indigo Digital Presses' started by jetscreamer, Nov 25, 2022.
  1. jetscreamer
    jetscreamer Senior Member
    Apr 2009
    140
    Kenilworth australia
    Is it common for the pip to skew so much that the tail will eventually (70-80 000 impressions) touch the outer ring of the cylinder which causes imaging issues?
    Can I adjust the pip clamp pressure?
  2. White rabbit
    White rabbit Member
    Apr 2013
    72
    USA
    it shouldnt move from its initial position. check first transfer and bid pressure ?
  3. michal
    michal Member
    May 2012
    21
    UK / Poland
    may need to replace pip clamp. Also your wetting roller can cause that problm. Make sure you have Cleaning station oil flow ok, wetting roller is not worn out-bearings also
  4. krukov
    krukov Member
    Oct 2019
    79
    IDK
    You need to check PIP foil clamp, maybe clamp is holding pip weaker on front/rear side. Take it out, disassemble , clean inside and check again. Skew can be caused by 1T pressure issue, printing engine leveling, cleaning station rollers worn out/engage issue, cleaning station oil flow problem.
  5. michal
    michal Member
    May 2012
    21
    UK / Poland
    It's not normal that pip is touching slip ring even in the end of its life. Do you put oil under pip foil all around drum to make sure foil stay safe? If pip will touch slip ring then you will see kind or rainbow image.
    Pip clamp doesn't have any adjustment. It's good or not
  6. Raju
    Raju Member
    Nov 2017
    36
    New Delhi, INDIA
    May be you need to replace the underlayer, ITM ir sensor calibration
  7. krukov
    krukov Member
    Oct 2019
    79
    IDK
    ITM IR sensor is not affecting to pip skew.
  8. jetscreamer
    Apr 2009
    140
    Pip no longer skews, I just needed to clean out the pip clamp. All good now.
    Raju likes this.
