Photopolymerization of coated stock on UV LED press
Davino
2026
57
Los Angeles, Taipei, and Riga
A key development, after months of investigation, on what has been occurring to Arctic Volume White and Sappi Magno Matte paper stocks with a UV LED press (our printer has a Speedmaster XL 106-8 LED), explaining the stock's transformation, surface degradation, and destruction of its tactile properties on press. Here it is, verbatim, from the printer after consulting with their supplier:
"The explanation from the paper supplier is that the original factory-applied native tactile coating of the Arctic Volume White paper contains chemical monomers, oligomers, or haptic resins that create the pleasant, luxurious tactile feel (such as micro-slip, velvet soft-touch, or the natural paper roughness).
"The UV LED curing energy is indeed reaching the unprinted areas (margins, gutters, and white areas). This exposure can trigger unintended photopolymerization (cross-linking) within the paper's native tactile coating. As a result, the chemical structure of the coating hardens and flattens, which reduces the premium tactile effect and causes the surface degradation observed on both proofs.
"We use the same settings across all our printing machines, so no recalibration off ICC profiles is required."
It's surmisable that the difficulty incurred in establishing this unintended photopolymerization effect on the precision-engineered surface coating is partly due to the printing and publishing fields being concerned, first and foremost, understandably, with the quality of the printing, not the tactile, haptic qualities of the paper. After months of dedication to addressing the shortcomings of what we intentionally designed into a major publication's aesthetics and haptics that were being lost on press (specifically, overcoming the glossy text from UV LED printing and trying to maintain the original tactile nature of the paper stocks chosen explicitly for the hand-feel/tactility), this brings us now to the first admission from either the printer, the paper supplier, or the paper manufacturer of what are major issues with the UV LED process, specifically with these premium stocks.
Are there tactics to cope with this, for example, in the Heidelberg DryStar LED system's Auto Format Setting, which masks LED segments outside the print area, and allows lamp intensity control per page section? If intensity was stepped down to the minimum threshold needed to cure text ink – rather than held static at image-page levels – it may simultaneously reduce haptic coating degradation in unprinted areas AND reduce ink gloss on text. One press adjustment potentially addressing both problems. A step-wedge power reduction test on a dummy run may help establish whether this holds in practice.
Otherwise, to move the entire project over to traditional offset would mean recalibration of hundreds of images that were retouched (over hundreds of hours) and optimized with proofs for their UV LED. I'd also expect the text to print with more dot gain, which with UV LED doesn't happen, curing instantly as a film. There'll be more see-through with offset on the 130gsm stock as well.
Text is considered line art and doesn't have "dot gain" since there are no halftone screen dots/tints.
However, UPC bar codes are also line art but may need some line width reduction treatment, especially unidirectional parallel to cylinders, (slur/doubling).
I don't think the text (size/shape) will be noticeably different between conventional and UV ink systems.
130gsm paper is about 0.007" thick (depending on bulk) and should have good opacity with little "show" (paper) or "strike" (ink) through from the other side.
  • Following up, we're now evaluating whether to switch this job from UV LED to conventional offset, and I'd welcome input from those with direct experience. Background: the job is a heavily illustrated critical edition, approximately 400 pages, 4-colour plus one PMS spot (Pantone Cool Grey 8C for annotations), on Arctic Volume White 130gsm. Files are calibrated to FOGRA51/PSO Coated v3. Images were retouched and colour-corrected and validated with wet proofs on press to FOGRA51.
    Three problems are documented on the UV LED proofs: (1) high gloss on text ink, unacceptable on a matte stock in a dense scholarly edition; (2) irreversible photopolymerisation of the stock's native haptic coating across the entire sheet including unprinted areas, confirmed by the paper supplier; (3) orange peel / reticulation on photographic solids – this is tolerable (unlike points 1 & 2) but also due to UV LED.
    The questions I'm trying to answer before recommending the switch:
    1. Our files are built to FOGRA51. How portable are they to conventional offset; are we looking at significant recalibration of images, or should FOGRA51-profiled conventional offset reproduce them faithfully?
    2. On conventional offset on Arctic Volume White 130gsm: what dot gain should we anticipate on photographic solids, and is it significant enough to require image adjustment? (We'd likely varnish the images to bring back some saturation to them, but not flood coat.)
    3. On show-through: Steve noted 130gsm should have good opacity. But if ink is absorbing into the stock on conventional offset rather than sitting on the surface as with UV LED, does that absorption affect show-through measurably at this weight?
    4. Has anyone switched a job mid-production from UV LED to conventional offset on the same stock and files, and what was the practical experience?
      Fogra51 is a German standard, but based on global ISO 12647-2, for sheetfed offset lithography, using popular conventional oil-based inks. Fogra39 is an older spec that used M0 instrument lighting (tungsten), where as Fogra51 uses the current M1 instrument lighting that uses D50 + UV content to simulate 5K daylight. Using Fogra51 should be fine.
      Fogra51 assumes a Light Weight Coated (LWC) paper, gloss or dull/matte/satin. Fogra52 is for uncoated, plain paper. Dot gain is now called Tone Value Increase (TVI) and the standard shows a tone curve for various types of papers. In the USA, we measure TVI at the 50% screen tint, but European has a preference to measure at the 40%. The 40% will maybe be about 1% less than the 50%. The expected CMY TVI is about 19% for 175lpi AM halftone screening. The K ink will be about +3 more, so 22%, than the CMY inks. Solids, being 100%, cannot have any TVI, so have 0%. A dry raw black ink on gloss coated paper might measure 1.70 density, on dull/matte/satin paper maybe 1.50, and on uncoated paper about 1.20.
      Shrow-though is a paper issue. The heavier the gsm weight, the thicker the paper caliper, the more opaque it is. Strike-through is an ink issue from fiber capillary absorption. The paper's surface coating acts as "sizing" and should minimize this. That is not the case with uncoated papers. I wouldn't expect 130gsm (7mil, 7pt paper) to be an issue.
      UV, both conventional Hg (mercury) and LED are known to have more TVI than oil-based inks. However, a compensation/correction curve can be added at the Raster Image Processor (RIP) or Digital Front End (DFE) to make them match. The file does NOT need adjusting! The dots on the plate (Computer-to-Plate (CtP)) are adjusted. It is often called a cut-back curve because the UV inks dots are larger and need to be made smaller to match oil-based inks. The printer having both conventional and UV presses, probably already has done matching tests and have UV compensation plate curves already.
    Normally for all of the issues above, most graphic artist/designers and buyers don't get involved in these sophisticated levels of technical details. The printer often says, "A little knowledge is dangerous." The printers experience and knowledge make them the expert.
    1. Do conventional sheetfed offset presses running standard oil-based inks incorporate any UV drying components, under any configuration, active on the sheet during the print run — or is drying purely oxidative?
    2. Is it possible that a large printer running both conventional and UV LED presses may have UV units retrofitted onto what are nominally conventional presses?
    3. For a spot varnish on photos on Arctic Volume White 130gsm in conventional sheetfed offset — aqueous or oil-based overprint varnish? The goal is to restore saturation and richness to images on matte stock without any UV curing components involved.
    If we make this switch to traditional offset, I need certainty that UV-induced photopolymerisation of the paper's native haptic coating cannot happen again. Designers don't normally engage in this level of technical detail, and that's right. I was thrust into this by necessity — the printer made an undisclosed process decision that irreversibly altered the specified stock, and a long investigation followed before the cause was confirmed by the paper supplier. I raise these questions not to second-guess the printer's expertise, but because that expertise was not applied in our interest when it mattered most."
    No, conventional sheetfed offset lithography that uses oil-based inks ONLY dry by oxidation/polymerization. Much like oil-based paints. They need air (oxygen) and time (minutes to set, hours to dry). Without any varnish or coating, they may be using anti-setoff spray powder to separate the wet sheets so they don't contact touch each other and transfer ink (setoff/block). They may have an infrared (IR) drier but that is only thermal heat to speed up the process.
    Yes, this is common on older presses. But it would be either one or the other but never both at the same time.
    Yes, either will work. Recall an earlier conversation about the differences between a varnish (oil-based, applied by rollers, spot needs a litho plate, better register fit) and coating (Water-based/Aqueous AQ, applied with special unit and roller (rubber or ceramic flexo anilox, needs an expensive relief plate/blanket, register fit may be less).
    Either will increase the top surface smoothness (flat), thus increase specular directional reflection, and increase optical density, making it look darker and provide more contrast.
    I think another press proof would provide that assurance.
    As you know, I've been following this issue from the very beginning, under multiple but similar threads. I sympathize with you. The paper coating being UV sensitive was a surprise to both you and the printer.
  • Following up on this thread with a significant and unexpected development.
    Our hand was forced and proceeded with the switch to traditional offset, now back in Taiwan, on a Heidelberg Speedmaster CD 102 5+1 at a Heidelberg certified printer. We ran test print last night on sheets of Arctic Volume White 130gsm and Sappi Magno Volume 135 gsm. I was on press.
    The tactile degradation in unprinted areas (the long-standing issue) is still present. It's less severe than the UV LED result, but markedly there and easily discernible compared to the sheet's condition before running through the press. This rules out UV-induced photopolymerization as the sole degrading mechanism. Something in conventional offset press is also affecting the stock's native tactile coating. Is this normal? It should not be if these specific tactile qualities are what the stocks are marketed under.
    The two causations candidates I’m now looking at are dampening solution and nip pressure, either independently or in combination. Both contact the unprinted sheet. I’d like to isolate them. Whether the CD 102 can be configured for that mode is a question I'm posing here. I welcome input on whether this is the right diagnostic approach, and whether there are known interactions between fountain. A “blind run” or “dry run” seems necessary: pass stocks through all mechanical contact points — rollers, blanket, impression cylinder — without ink or fountain solution. If surface degradation appears, it’s mechanical (nip pressure, roller contact). If it doesn’t, chemistry is involved. Yes?
    Test 1: Can the CD 102 run with dampening off and ink rollers lifted? (pure dry run — isolates nip pressure only)
    Test 2: Can the CD 102 run with dampening active and ink rollers lifted? (isolates fountain solution chemistry)
    Sappi and Arctic have been contacted again; their input is awaited, but one asks for me to supply sheets for review when all I have is one copy - I've requested they obtain them from the printer. But hitting the same wall again has been very hard. I'm left theorizing at this point that the entire industry functions without this level of attention to matters which are tactile. That Sappi and Arctic provide such stunningly beautiful, tactile paper samples and bound dummies that, in practice, have zero or a slim chance on press of retaining these tactile qualities, is the final conclusion left to entertain if they can't help explain how to avoid the degradation.
    Yes, press can perform both test conditions of impassion pressures only (physical/mechanical) and also fountain solution only without inking, but you will need a non-imaged plate.
    I would be surprised if both show any change.
