Perfecting or Straight Press?
Discussion in 'Heidelberg Printing Presses' started by Adil Nawaz, Jul 21, 2021.
  1. Adil Nawaz
    Adil Nawaz New Member
    Jul 2021
    Pakistan
    Hi, i want install a Heidelberg SM-52-6 for my packaging business. However, I am counting my options between straight and perfecting press. Can someone here guide me either I should choose Straight or Perfecting unit for boxes, cartons, packaging printing.
    Thank you
  2. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    178
    india
    Hi
    For packaging always best option is straight press
    asem alsafady likes this.
  3. Waqas_zahid
    Waqas_zahid Senior Member
    May 2011
    222
    Pakistan
    Hello,
    Like ashok mentioned best option is to go for a straight press, where are you located exactly in Pakistan?
    Regards,
    Waqas
  4. Adil Nawaz
    Jul 2021
    Pakistan
    can you please explain why straight press is better than perfecting press for packaging?
  5. Waqas_zahid
    May 2011
    222
    Pakistan
    Depends on your particular job, generally there is no printing required at the back of board in packaging so why spend the extra money? However there are many customers who got a perfecting machine in good price and they use it for packaging without ever using the perfector.
    If you are getting a used perfector in good price you can install that and just do not use the perfector if you dont have a requirement for it.
    A printer might be able to shed more light on the subject also.
  6. narayan
    narayan Member
    Dec 2009
    56
    Nepal
    In Perfection, the gripper assembly is very complicated. Gripper opening cam, Storage drum reversing drum, sensors, hydraulics, hydraulics clamps are few things that has to be aligned perfectly. If one of them are not aligned properly then there will be problems. So if you don't have perfection jobs then straight machine is the best option.
    turbotom1052 and asem alsafady like this.
