Perfecta 92 TVC Needing Motherboard
fourcolordemon
2023
Work
I have a perfecta 92 TVC I have been working on and can not find parts very easily here in the US. I am looking for the main board that goes behind the display that attaches to the frame. I am assuming its the main/motherboard. It was working perfectly until it started power cycling on the the down stroke of the cut. Once it gets to the bottom of the cut the system reboots, and wont complete the cut. I have to power cycle it, and then it will finish the cut. Any help would be greatly appreciated.
Hello there,
It would be more helpful if you share the pictures as well of the board.
For the problem on the machine, share more details with pictures.
  • I have enclosed pictures of the board in and out of the trimmer.
    Let me know, what is his country for delivery for calculate freight with the factory, send me his email please with details, by Rules of Forum i can NOT supply.
    As far as I understand from your message, when you press cut switches —> knife moves down —> when Knofe reaches the Bottom —> system reboots
    My experience says, please follow as
    1- Keep an analog multimeter connected at the board input supply 24VDC, enable cut, when the knife is moving, if there is any voltage drop, this board will reboot
    2- Check the CAM switches and there cables, as these 24V signals become active when knife moves down, if the cable is making short circuit with ground, it might reboot the board.
    3- Check the Transformer step down vomtage
    4- On this board, there is small computer with RAM and processor, please check the connection of this computer and RAM slot.
    5- You can order the board from PERFECTA Germany.
    It would be great if you make a video when you enable the cut and how the display board reacts.
    Hi, I'm also looking for that motherboard, I have a Perfecta 115 TVC but the motherboard itself is similar if not identical, I have a problem with PC/104 486 Board. All voltages are fine but there is no signal on the screen. Do you know if I can replace it with something different ? And do you have a program for It or BIOS flasch ??
    Hi Sir :
    For all cases using perfecta machines Need :1) parts number 2) Pics 3) ID plate 4) Country of delivery, and Email
    I can Supply Parts. + Others.
    Hello
    Thank you for yours time.
    This is the part that i need.
    My email is kris123061@gmail.com
    Im from Poland.
    Hi,
    If you have this part i will wait for yours email.
    Thank you very much for yours time.
    Dear All,
    I have a problem with Perfecta 92 TVC.
    After switching on the machine and making fun cuts, the screen goes dead. I am unable to input and measurements at all.
    Can I any help?
    Measure the regulated power supply, in the moment of screen goes out, there must be in tolerance from 0.& % up or down, otherwise, the power supply is faulty .
    However test the cables, for corrosion, or loose, or broken wires.
  • Hello Sir,
    Perfecta 92 TVC screen hangs while using. Is the CPU available for this machine? The message shown in the photo appears while switching on the machine and does not go while pressing Cancellation button.
