Paper sticking to the blanket.
Discussion in 'KBA Printing Presses' started by Eric.K, Mar 4, 2025.
Tags:
  1. Eric.K
    Eric.K Member
    Aug 2013
    44
    NAIROBI, KENYA.
    Hello all, I have a problem with the sheets sticking to the blanket while printing, sheets don't show signs of getting to the gripper, so, they stick to the blanket and roll up into the inking rollers, please help with a solution.
    This is on a KBA 106, i have rechecked the grippers,twice, used a different ink but same problem, please, anyone with a solution?
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,111
    Vermont
    Just when do you experience the sheets sticking to the blanket? Every time you start the press? During makeready? After press has been down for a bit and the blankets have not ben washed? When printing large solids? There are lots of situations that could cause this issue. You will need to better describe your conditions when this occurs.
