HomeBasedStationer
- 2021
- 2
- New Jersey
Hi all!
I run a small stationery business from my home. I exclusively use 120 lb. Smooth Digital i-Tone cardstock from Mohawk. Somehow I managed for 3+ years to operate at a substantial volume (~4,000 prints per month) using an HP m553n (Don't laugh!
I went through two of these and a number of refills of toner). Customers and clients have always been extremely happy with the print quality and end product, but as you can imagine there have always been kinks to work out in the day to day.
After years and years of discussion and debate, I finally decided to move forward with purchasing the OKI c931, which even though the business is doing well, is a substantial investment for this little operation of mine. I was really hopeful this would be a huge upgrade from my little HP m553n and improve quality and process even further but ... yikes.
The c931 is meant to be able to handle up to 360 gsm from the MP Tray. The paper I use is ~325 gsm, cut down to 4.25"x5.5". It's a relatively straightforward pathway from what the tech who installed it is telling me, but it's curling the edges of the paper regardless of the setting I try. I've tried all Media weights, turning High Humid Modes on, Moisture control, adjusting the printer speeds. Nothing fixes it. It's especially apparent when running your fingers over the paper that a ridge is being created by an internal wheel. This never ever happened using the HP m553n. See attached.
Also worth nothing that the paper is coming from shrink wrapped packages that are not opened until ready to print, so I really don't think it's a humidity issue.
Does anyone have similar experience with this machine or is anyone able to share insight? The reseller I purchased from has so far been largely unhelpful and pretty unresponsive.
Thanks in advance!
Thanks in advance!
