Nicky G.
- 2024
- 18
- Italy
I have a printer that is leaking toner onto the transfer belt; as a result, even though the prints come out well, they get stained by the loose toner.
I’m asking for your help:
1. How can I figure out which toner cartridge or drum unit is leaking?
2. What if the issue is the belt itself failing to clean properly and releasing toner?
3. Is there a way to remove all the toner cartridges and drum units and test them one by one to identify the source of the leak?
4. What if the problem is the drum unit's seals? How can I replace them or install something to act as a seal?
