oil pressure error beep
Discussion in 'Heidelberg Printing Presses' started by Print Icon, Feb 4, 2021.
  1. Print Icon
    Print Icon Member
    Jan 2021
    8
    India
    when machine iph goes over 3500 a beep/alarm start. I've checked oil lavel. It is upto top mark of oil lavel.
  2. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    hi dear sir, please can we see what the screen displays when the beep is heard. thank you and stay blessed
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,035
    US, Midwest
    Model and age of machine? Do you know that the oil pump is running?
  4. Print Icon
    Print Icon Member
    Jan 2021
    8
    India
    hi junker, oil pump is running . machine model is sm 72v 1989 year
  5. Print Icon
    Print Icon Member
    Jan 2021
    8
    India
    @Beguin, in tronic display, 1bar symbol is lit up and 12 bar symbol blinking countinuesly.
  6. junker1984
    Jan 2010
    1,035
    US, Midwest
    OK, begin by cleaning the pick-up screen, under the round cover of the last printing unit, located on the end of the lower cover. It’s held in place by 6(?) 6mm bolts. Screen is difficult to access, but having done it many times, it just takes patience and a bit of ingenuity. Hex on screen is 24mm and fitting nut is 19mm. Once that is accomplished, and problem remains, you must check pressure switches located under register drum, fastened to side frame near base frame. On the display screen, when you have selected oiling icon, which number is above preset value, 1 bar or 12 bar?
  7. twrick351
    twrick351 New Member
    Feb 2021
    United States
    May be, sign of low oil pressure and showing error on screen..need to reset it
