offsetting
Discussion in 'DI Presses' started by sbaylor, Dec 9, 2010.
  1. sbaylor
    sbaylor Member
    Oct 2010
    16
    Lawrenceville, Georgia
    Running on 100# uncoated sheets with medium coverage and getting some offset. What can I do on the DI and any paper suggestions with good results?
  2. Marc Bremer
    Marc Bremer Senior Member
    Jan 2010
    239
    Netherlands
    What is maximum coverage (should be 280 or less)
  3. Litho
    Litho Member
    Mar 2010
    39
    Rochester, Ny
    make the sheets deliver as flat as possible, lower your ir, and slightly increase your powder. when removing from the delivery try not to shock the lift, or fan through it right away
  4. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
    Run smaller lifts. Sometimes depending on the job this is what is needed to get it done without offsetting.
  5. Aljenn
    Aljenn Member
    Jun 2011
    7
    Jacksonville, FL
    You might try changing your powder to AirTech Brand, it is finer, and works extremely well. You can use less powder and your don't have issues when flipping the paper for backup due to too much powder. I've run Airtech for the last 4 years and only had offset issues with particular brands of paper.
