Numbering unit SM52
mantman
2015
306
Greece
Hello I am facing issue of numbers will not print on paper even though I put max pressure of numbering unit.
I am using numbering boxes of GTO -I presume they are the same for SM-. One thing i noticed that after manually throw on impression of numbering and sliding a paper between box/jacket, after folding it several times -close to -0,5 mm- it snagged the piece.
Could it be the jackets are wrong? Not sure if jackets are original from Heidelberg or aftermarket.
The numbering heads on the SM52 and GTO52 are different, as are the cylinder diameters.
  • The numbering heads on the SM52 and GTO52 are different, as are the cylinder diameters.
    Thank you for your reply, heads as in boxes? I am not so sure i looked it up at sites selling numbering boxes and they say GTO/SM.
    Update:
    Problem solved there was a custom made block with threads that stopped the complete movement of arm
