Nexpress 2500
Discussion in 'Kodak NexPress Digital Presses' started by richpadg, May 14, 2013.
  1. richpadg
    richpadg New Member
    May 2013
    North Charleston, SC
    Is it possible to run a job back through the Nexpress for glossing after it's been printed?
  2. illyith
    illyith New Member
    Nov 2015
    cleveland ohio
    The glosser is a separate unit. You put a gloss coat with the clear on the sheet, then run it trough the glosser. Make sure you have the substrate settings set for glossing or you wont get the barcode the glosser needs to set the temp and pressure.
