New MP9000 Ricoh
art post
2008
11
USA
System has only 2,000 pages on meter, inlcudes print, scan, document feeder, and booklet finisher/stapler. System print and copy speed is 90PPM. Contact art@p4photel.com
90 day parts & labor warranty (included for upto 100k)
$16,995 (plus tax & shipping)
Optional Services:
On-Site Training for Hardware and Software $150 per hour
Network Install for Printing and Scanning $150 per hour
Additional Maintenance Agreement can be purchased (Call for price)
Lease Financing for up to 60 months (Based on credit approval from third party leasing company) Call for lease quote
On-Site Setup (remove packaging, install finisher, test, and check operations) $375
General Features:
Dual toner bottles allow change-on-the-fly, uninterrupted output
Dual tray Interposer option provides ability to insert color or preprinted sheets
Dual 160GB hard disk drives (320GB)
Large, user friendly, dual language color touch panel display for simple access to all functions
Large standard memory of 256MB RAM
Desktop control of an extensive list of advanced capabilities
Connect Copy option allows the linking of two Aficio MP9000's to double your output to 180 ppm
Print speed of 90 ppm
True 1200 dpi resolution
Network Scan-to-Email and Scan-to-File with printer and scanner kit options
Copier Features
Seven paper trays with total paper capacity of up to 8,050 sheets
Enhanced Document Server allows you to easily retrieve/merge and edit files in thumbnail format for enhanced productivity
Full finishing capabilities including covers, chapters, tab extension copying, printing, stapling and user selectable 2 and 3 hole punching
Scan black & white or color images at 80 ppm
Scan Once, Print Many with fast, clear output at 90 ppm with 1200 dpi resolution
Printer Features
Perfect for local or network printing with either PC or Mac
PCL6 enables it to work with all popular applications
Works with Windows ME/2000/NT 4.0/XP/Server 2003 and Macintosh 8.6 or higher
Print Resolution PCL5e 300/600 dpi, PCL6 600/1200 dpi, RPCS 200/300/600/1200 dpi, PS3 600/1200 dpi
Optional Accessories:
RT5000 (LT/LCT) Letter Sized Large Capacity Tray
Dimensions 21.2” x 28.7” x 38.5”
Power Source From Mainframe
Supported Paper Sizes All Trays: 5.5” x 8.5” to 8.5” x 11”
Supported Paper Weights 4th Tray: 16 lb. Bond - 80 lb. Cover, 5th Tray: 16 lb. Bond - 80 lb. Cover, 6th Tray: 16 lb. Bond - 90 lb. Index
Total Capacity 3 Trays / 4,550 sheets
Tray Capacity 4th Tray: 1,000 sheets, 5th Tray: 1,000 sheets, 6th Tray: 2,550 sheets
Weight 194 lb.
BY5000 Multi Bypass Tray
Dimensions (WxDxH) 26.7” x 22” x 7.1”
Paper Capacity 500 sheets (based on 20 lb Bond)
Paper Size 5.5” x 8.5” - 13” x 18” (with RT5010 DLT/Large Capacity Tray)
Paper Volume Sensors 100%, 50%, 10%, Near-end
Paper Weight 16 lb. Bond - 80 lb. Cover
Power Source From LCT via Mainframe
Weight 39.6 lb.
ZF4000 Z-fold Unit
Dimensions (W x D x H) 6.9" x 24.4" x 37.8"
Weight 121 lbs.
With Proof Tray Sizes: 8.5” x 11”, 8.5” x 14”, 11” x 17” SEF Paper Weight: 17 – 20 lb. Bond
With Shift Tray Paper Size: 8.5” x 11”, 8.5” x 14”, 11” x 17” SEF
With Staple Tray Paper Size: 11" x 17"
GBC StreamPunch III
Available Die Sets GBC 3-hole Die Set, Ring Binder, GBC 11-hole Die Set, VeloBind, GBC 19-hole Die Set, CombBind/GBC Type, GBC 21-hole Die Set, WireBind 2:1, GBC 32-hole Die Set, WireBind 3:1, GBC 44-hole Die Set, GBC 32-hole ProClick
Dimensions (WxDxH) 12” x 28.5” x 38.5”
Power Consumption 340W
Power Supply 115V AC, 60 Hz, Single Phase, 3.0 A
Punch Capacity Single Sheet
Punch Edge 11” edge of 8.5” x 11”
Punch Stock Weights 20 lb. Bond - 80 lb. Cover
Sheet Size 8.5” x 11” (no tabs)
Speed 90 sheets per minute
Weight 154 lb.
RT5010 (DLT/LCT) Ledger Sized Large Capacity Tray
Dimensions (WxDxH) 34.7” × 28.8” × 38.6”
Supported Paper Sizes All Trays: 5.5” x 8.5” to 13” x 18”
Supported Paper Weights All Trays: 16 lb. Bond - 80 lb. Cover
Total Capacity 3 Trays / 4,000 sheets
5th Tray: 2,000 sheets
6th Tray: 1,000 sheets
Weight 363.8 lb.
SR5000 3,000 Sheet Finisher w/100-sheet Stapler
Dimensions (WxDxH) 31.5” x 28.7” x 38.5”
Output Jogger Standard
Power Consumption Less than 120W
Proof Tray Stack Capacity: 500 sheets (8.5" x 11" or smaller), 250 sheets (8.5" x 14" or larger)
Paper Size: 5.5" x 8.5" – 13" x 18"
Paper Weight: 14 lb. Bond – 80 lb. Cover
Shift Tray Stack Capacity: 3,000 sheets (8.5" x 11"); 1,500 sheets (8.5" x 14" – 11" x 17") 1,000 sheets (13” x 18”) 500 sheets (5.5" x 8.5" LEF) 100 sheets (5.5" x 8.5" SEF) 30 sheets when Z-folding
Paper Size: 5.5" x 8.5" – 13" x 18" Paper Weight: 16 lb. Bond – 80 lb. Cover
Staple Capacity per Set 100 sheets (Letter) 50 sheets (11" x 17", 8.5" x 14", 8.5" x 11" SEF) 10 sheets when Z-folding
Staple Positions Top, Bottom, 2 staples, Top Slant
Weight 165 lb.
BK5010 Production Level Booklet Maker
Dimensions (WxDxH) 55.9” x 27.6” x 35.4”
Finishing Speed Maintains rated engine speed of 90-ppm
Maximum Booklet Capacity 30 sheets (120 pages based on 20 lb. Bond)
Power Consumption Less than 200W
Power Source 100/100/115/127/220/230V 50-60Hz
Supported Paper Sizes Width: 8.1" to 12.6" Length: 10.8" to 18"
Supported Paper Weights 16 lb. Bond – 172 lb. Index*
Weight 286.6 lb.
*BK5010 supports up to 172 lb. Index in Off-line mode only. The Pro 906EX/1106EX/1356EX support up to 80 lb. Cover (120 lb. Index) On-line when combined with the BK5010.
Optional BK5010 Production Booklet Maker Accessories
BF5010 Book Folder Creates a square fold from a saddle stitched book
BK5010 Rail Unit Eases finisher docking/undocking
CF5010 Cover Feeder Inserts preprinted/color sheets as covers
TR5010 Trimmer Unit Trims edge of the booklet for a professional finish
PU5000 Hole Punch Option for the SR5000 Finisher
Hole Positions 2 or 3 holes, switchable
Punch Paper Size 5.5" x 8.5" – 13" x 18"
Punch Paper Weight 16 lb. Bond – 90 lb. Index
TK5000 11" x 17" Tray Kit
Function Converts Tandem Tray to an additional short edge feed (SEF) tray
EB-135 Print Controller (Optional)
CPU Intel Celeron
Hard Disk Drive 80GB
Memory (Std./Max.) 512mb
Network Protocols TCP/IP, Novell IPX?SPX,SMB, AppleTalk with auto-switching
Printer Languages PCL6/PCL5e
Standard Interface 10/100/1000BaseTX
Utilities Command WorkStation 4.5, Fiery Web Tools, Fiery Scan (TWAIN plug-in, Remote Scan), Fiery FreeForm 2, Fiery WebTools, Fiery Mail Port, & Fiery Printer Delete Utility
