PhilV
We recently had a "new to us" Polar 92 ED installed. Upon installation, the back gauge failed to engage high speed while positioning in automatic program mode or manual movements. No errors were recorded in diagnostics.
Our installer reported the following:
This malfunction was described to a Polar Specialist who suggested certain items be checked and advised that the fault may be due to a faulty frequency inverter which controls current to the backgauge motor.
An SAP backgauge drive positioning control board and a frequency inverter were ordered with Heidelberg parts. A Lenze programming unit was used on the frequency inverter to view and possibly change/correct settings, but the display on the programming unit did not illuminate and was unuseable, meaning the inverter is causing this or the programming unit itself is at fault .
The new SAP control was installed with no change or correction of the speed failure. A new inverter has been ordered but has not arrived at this time.
Heidelberg service was asked to provide service assistance as the Polar Specialist had no prior experience with this speed problem.
If anyone has any thoughts or suggestions at this point, it would be very welcome.
Phil
Phil
