Mark Olson
- 2021
- 12
- Calgary
To adjust pressure for the impression cylinder on the ab dick 360 you have a lever on both sides when the machibe is open. I cant remember if it was more or less pressure that broke both of them but either way they are broke.
I have a few questions as this is very important to get fixed as soon as possible.
1. First I was to ask about the screw that is no longer there in which Seperates this lever. Was it screwing in that gives more. Plate to cylinder pressure or less?
2. Second question is the screw and nut that is still there. What is the point of that and what pupose does it do? What if I screw that nut up more or down more? I just want to understand that more because one was moved a bit already.
3. Here is my third and most important question. How the heck do I pull this lever off the machine on both sides so I can fix it? Is it just a nut that is in the inside and everything then slides off? And if it is just that which I suspect it is. How do I access this nut which is the part that makes me afraid? Do I have to take this machine apart and pull cylinders out etc just to get to this nut on both sides of the press? Because if thats the case its way past my pay grade and I will mess everything up and never be able to put it back together again. Can someone please tell me how I can take this lever off the machine on both sides by writing how to direct me and how its done. Or is there a hack that can fix these 2 broken levers where I can adjust pressure without them coming off the machine?
Thank you for your help!!!
