MUNK PSP Family / Series Gamma Bench Case Version D400 G150/50 WRG-TFKX 150V/50A DC regulated PSU
Alonex
2019
143
USSR
MUNK PSP Family / Series Gamma Bench Case Version D400 G150/50 WRG-TFKX 150V/50A DC regulated Power Supply Unit for Sale.
The power supply has been developed for applications in modern electrochemical process engineering.
- High Current Switching Mode Regulated Power Supply Technology.
- Current and Voltage Closed-Loop Control with improved dynamic response of the output.
- Compact design, high control accuracy, low ripple, low weight (40kg), high efficiency.
- High quality direct current, constant ripple, in contrast to other electronic rectifiers.
- Remote ON/OFF control, actual output current & voltage indication analogue outputs.
- Seven Segment LED actual output current & voltage indicators.
Electrical Data:
Mains Voltage: 3 x 400±10%, 47-63 Hz
Nominal DC Voltage: 15 0VDC
Nominal DC Current: 50 ADC
Efficiency: 75-90%
Ripple: <3% referred to nominal values
Adjustment ranges: 0-100% of Nominal Voltage/Current
Control Accuracy: ±1% referred to nominal values
Ambient Temperature: 0-35°C (30-100°F)
Condition: Pre-Owned, Working, Tested.
Manufactured: 07/2017
Alonex - Industrial & Special Purpose Power Supply Repair Services.
Alonex - Where The Art of Electronics is Alive!
Alonex Electronic Engineering Ltd.
Tel.: +972-3-5037095, Fax: +972-3-5031048
http://www.alonex.com/contacts.htm
E-Mail: i.alonex@gmail.com
Regulated Constant Voltage/Current Applications:
- Electrolysis of Chemical Liquids or Solutions
- Electrolysis of Water, Hydrogen & Oxygen Producing
- Electrolytic Refining of Metals, Wohlwill Process
- ElectroPlating, ElectroPolishing, ElectroEtching
- ElectroForming, ElectroTyping
- Electrochemical Water & Wastewater Treatment
- EP- Electrochemical Precipitation, ME - Membrane Electrolysis
- Electric Vehicle & Forklift Traction Battery Charging
http://www.alonex.com/pdf/AX-MNK.pdf
Alonex ICEE Labs
