Muller Martini Merit S
Discussion in 'Cutters and Trimmers' started by David Lee, Feb 16, 2024.
  1. David Lee
    David Lee New Member
    Apr 2023
    Viet nam
    Hello all.
    We have problem with Muller Martini Merit S. All axis motors and positon motors not in position.
    The machine gets problem when we change size of book from small to bigger.
    Can any body give me your solution to solve it?
    Kind regards
    David
  2. xmacs
    xmacs Member
    Mar 2025
    8
    Matosinhos
    Hi everyone,
    I need help in merit s
    Motor feed don't work, lost of times
    And appears in screen error code 081 motor feed error,
    M7
    G7 drive
    I change lenze drive, resolver, check cable, change the belts of the motor feed...
    Can anyone help me to resolve this problem???
  3. xmacs
    xmacs Member
    Mar 2025
    8
    Matosinhos
    I attached the photos.
    It's in Portuguese...
  4. Jose Chacon
    Jose Chacon Member
    Apr 2020
    17
    Venezuela
    Probably module NC150 is broken.
  5. Jose Chacon
    Jose Chacon Member
    Apr 2020
    17
    Venezuela
    David you have to recalibrate or reference all the motors again in order to match the mechanical position with electronical position. this is made by muller martini service code.
  6. Jose Chacon
    Jose Chacon Member
    Apr 2020
    17
    Venezuela
    Xmacs did you check the Lenze Parameters? some time they are chenged by electrical problems.
  7. xmacs
    xmacs Member
    Mar 2025
    8
    Matosinhos
    Jose,
    Thanks very much for or help.
    I see the parameters os lenze drive because I have a backup all the drives of line...it's okay...
    The problem was a cable to connect in A7 ( DI )
    Now the its working fine...
