Muller Martini Amigo Plus Paper Jam
Bizegode
2019
37
Cote d’ivoire
Morning all
I have a problem with a Muller Martini Amigo Plus. In fact, the machine reports a "Paper jam" fault. However in reality no jam I checked the sensor it works perfectly. Does anyone have any idea where the error could come from?
I didn't understood with that glue equipment. I can assume that the sensor itself has failed (there is no signal to the controller or the supply voltage goes into the unknown)
Try to test the sensors by forcibly changing their signal with a piece of iron or a sheet of paper, while looking at the indication of the controller input lines.
You may need to disconnect the signal line from the controller to check the sensors (if the sensor in the normal state sends a signal constantly).
Also, I do not exclude the cause of the error caused by jamming / overload (protection operation) of the main stroke electric motors or the milling module.
ATTENTION! Turn off the main switch when manually turning the cutter!
  • I checked the sensors. They are all functional. I even swapped them the problem remains.
    I even checked the sensor signals on the module, everything is normal.
    @Bizegode
    Check the limit switches for the "load limiting coupling" and the glue bath if it is removable. try to turn the machine manually, our Tigra, when the full block is jammed, unlocks the "load limiting clutch" and you have to turn the machine manually to restore synchronization and clutch coupling.
    Also, manual cranking will allow you to understand whether the transmission is spinning easily and where there are jams or jamming.
    What if your main engine is jammed from old bearings?
    Error
    When I deactivate the cover take, the machine runs normally without stopping.
    On the first two photos, the cover sensor and its reflector check their cleanliness and serviceability.
    In the third photo, an incremental encoder is a device that allows the central controller to know the position of the machine's rotation with an accuracy of 1 degree. I hope the rotation of the machine works without the overlay of the cover, so it's not in it.
    yes that's exactly it. I think the problem may come from the modules. is there a way to reset?
    here is a picture of the mods. here is a picture of the mods. it is as if the modules keep the error in memory.
    The cover sensor is optical, based on the reflected signal. You can wipe the reflector with a dust cloth. If there is a sheet, it should turn on the "operation" LED.
    The encoder is more difficult, it gives three signals to the main controller. It can be checked by starting the machine in the setup mode in different angular positions and checking the operation of the automation with the "eye", evaluating the correctness of the stop in the selected position.
    I checked the eye, it works correctly. I also checked the encoder by the different positions of the automatic timing, no problem
    Then check the signal from the cover sensor to the controller. Place some covers and feed them into the machine in setting mode. See that the LEDs on the sensor and the main controller turn on at the same time.
    Is there a vacuum on the suction cups? Do the suction cups move when the car is turned?
    Is the vacuum cutoff solenoid working?
    The vaccum cutoff solenoid work good. I just finished checking it.
    The sensors are OK, the valve is working.
    The cover feed mechanism seems to be working as well. But there is no cover. Has the compressor been serviced? Are the compressor filters clean? Graphite blades without chips?
  • I overhauled the compressor yesterday, no problem with graphite blades and filter are clean. suction or discharge
    I even tried to reset the API. doing this procedure.
    PLC Initialization In order to bring the controller to a defined start state, it is recommended to reset the PLC according to the following steps before continuing: 1. Press and hold the stop push button 3PB (S3 ). 2. Turn main circuit breaker ON. The "machine on" light above the main circuit breaker illuminates. 3. Release the stop button. 4. All PLC variables are now reset to factory defaults and the controller is ready for operation.
    The API is reinitialized mqis the problem persists.
