MR306 CFM usage?
Discussion in 'Man Roland Printing Presses' started by thunderbird press, Nov 26, 2024.
  1. thunderbird press
    thunderbird press Member
    Jan 2024
    34
    canada
    I was told by Man Roland tech that my press requires 16CFM per printing unit and my old 5horsepower compressor(16CFM) Can no longer keep up. Along with another 5 horsepower compressor running at the same time the air at press is about 4-4.5 bar. I have fixed all air leaks and hear nothing coming out of any pistons or air cylinders. All air solenoids are quiet. Do I need new compressor? and Should I buy something with double the CFM and horsepower?
    Thank you guys!
  2. Daniel.Sanchez
    Daniel.Sanchez Senior Member
    Apr 2020
    171
    peru
    You colors have
  3. Asim Shehzad
    Asim Shehzad Senior Member
    Feb 2021
    126
    Lahore, Pakistan
    you need 9 bar air pressure to run the machine without any compressed air error. F005 is an air pressure switch installed on the machine to detect the minimum (5.5 bar) air pressure.
  4. thunderbird press
    Jan 2024
    34
    canada
    my compressors(both of them) build up to 150PSI, i then open the valve to the press and it turns into 90psi and the gauge at the press reads 4.5bar. Im probably drawing a bit more air because the machine is old and has small air leaks. Do you guys think a 7.5HP compressor will be sufficient? or should I go 10HP since i have to run 2 compressors at the moment?
  5. drukman
    drukman Senior Member
    Mar 2016
    431
    Bulgaria
    Normally the R304 works with a 3KW Becker piston compressor (= 5KW chinese garbage). Depending on the air leaks in the machine, you may need to use a 25KW compressor. .....or more.
  6. thunderbird press
    Jan 2024
    34
    canada
    does anyone know how much actual CFM is required? that will help me choose the right compressor to order, im deciding between 7.5 and 10 HP screw compressors with 125-150psi.
  7. drukman
    Mar 2016
    431
    Bulgaria
    Roland is a German machine. In Germany it is not measured in fingers, palms, feet, etc. There they measure in meters. Depending on the series of the machine and the number of PUs, it is between 330 and 950 l/m at 9-11 Bar
    If you give me a Telegram number, I will send you all the documentation for the air supply.
