I'm from a company in Canada and am looking to buy an offset press, I need some advice as I am quite inexperienced with offset presses. We are looking to buy either a heidelberg or komori 6 color press, with UV lamps.
What sort of costs should be considered?? (maintenance, parts)
How should we decide on the size of the press, the number of colors on press, etc.
What year should we buy?? Should we buy as old as possible, or is that a regretable decision.
We are also looking for a consultant to help us buy equipment, PM me for details.
Here are a few quick things -
-Availability of parts needs to be considered with any used equipment. It is hard to get parts sometimes for older machines, even if they run well.
-How well the press runs can be relative to how well it was maintained. A 5 year old press that was trashed, or a 10 year old that was precisely maintained, would create different scenarios, right?
-Make sure you have foundational support in your building for the press as well as necessary utilities.
- Size of the press and number of colors is relative to what you want to print. What kind of items will you be printing? What color needs will there be? Need to take that in to consideration.
- At the very least, you will have regular costs in your "consumables" (or items that need regular replacement on press, such as blankets, grease, feeder items, etc...)
- Costs can be dependent on staff also. An experienced operator might cost more to employ, but run less waste and make fewer mistakes (not always, but is a possibility) If the press will be learned from scratch, count on "learning costs"
- Parts are a tough one. Hard to predict which parts you will need and the costs, since they can range from moderate to very expensive pricing.
- Maintenance
time needs to be accounted for if you plan on keeping a well maintained machine. Time is money, and how much time is going to be devoted to maintenance will need to be determined. At the very least, it is good to calculate how much time is needed to follow the Manufacturers reccomendations to lubricate the press.
Wish I could give more specifics, but really we can't give you any hard numbers, only questions and issues to think of along the way, since every shop is different. Hope this helps!
-K
